06-12-2006 02:31 PM
06-13-2006 04:31 PM
06-14-2006 11:55 AM
Micaela,
The problem I have is NOT related to a need for a WAIT. I can view the signals show on my graphs with an o-scope on the SCB-68 terminals. The problem is related to creating a sample clock that is available at the terminals (to connect to my hardware) and used internally as the sample clock for the DAQmx Read function. The two VIs show illustrate the problem, on one the clock is available externally and the other internally. How can I make it work for both an external burst clock and an internal sample clock for the the read?
Thanks in advance for additional suggestions,
James
06-19-2006 01:51 PM
06-26-2006 09:27 AM
Problem Solved...
Just in case someone reads this thread in the future with a similar problem. I hate it when I find an old thread that matches my problem and the solution isn't shared. So here's my VI that solved my particular problem, maybe it will help someone else.
James
