From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Digital I/O
Python with NI USB-8451 OEM
Hello everybody.
My main goal is to use python to control some NI devices which I could do it with the NI USB-6501 OEM version but not the 8451.
I used nidaqmx in python and it's not working because I think the NI device is not recognized like the 6501 (not shown in NI device monitor)
I can see it with NI MAX and I renamed it into Dev3.
When I run these python line code for see every device connected it doesn't appear :
import nidaqmx
system = nidaqmx.system.System.local()
for device in system.devices:
     devices = str(device)
     print(devices)
console return :
Device(name=SimDev1)
I uninstall reinstall several time the NI 845x driver 17 (and 18, I'm using version 17)
I've try also with this http://www.ni.com/example/8911/en/
but according to the exemple 2 I've tried this :
I use -> physicalChannel = "Dev3" , not sure if it's correct but I've tried Dev3/ai0, Dev3/port0/line0 and it always return the same error.
Python 2:
Line 55 : returnValue = dll.DAQmxCreateAIVoltageChan(taskHandle, physicalChannel, channelName, terminalConfig, minVal, maxVal, units, customScaleName)
return : -200220
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PCxSAM&l=fr-CH
Error -200220 occurred.
Possible reason(s):
Device identifier is invalid.
Python3 :
Line 55 again
return : -200088
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QMjSAM&l=fr-CH
Error -200088: Task specified is invalid or does not exist.
If anyone can help me with that, because now I'm struggling and ruining out of idea .
Best regards
Adrien
(3,355 Views)
Hi Adrien,
the USB-8451 is no DAQmx Device so it will not work with the Python-DAQmx Library.
Unfortunately there is no Python Library available for this device yet.
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(3,331 Views)
Okay thank you for your answer.
But it means that even with the dll it will not work either ? Because we need to use the device name which implies to be an "DAQmx device" ?
Adrien
(3,327 Views)
Accepted by aguilem
Hi Adrien,
in the Readme of the DAQmx Driver you can find a list of supported Devices.
(3,317 Views)
Okay thank you, I checked and there isn't the 8451.
thanks for you answers.
(3,303 Views)
