Digital I/O
PXIe-6570 or Pxie-6556 as RFFE Slave
 Hi all,
I got a requirement something similar to the below case
  1. Needs to detect a rising edge in Pin 0 and respond high in pin 1.
  2. Needs to respond to the edge in less than 10 ns ie Clock edge detection to Data out time <10ns.
  3. Is it possible to achieve this in NI 6556 or NI 6570? (we can Ignore the external routing delay for now)
  • If we considered using the match pattern, we could see the minimum possible response time will be 800ns ie 80 clock cycles.
From the Datasheet of NI 6556
  • If we considered using hardware compare and script trigger, we could see the minimum possible response time is 1200ns
Looks like both hardware fails to meet the requirement theoretically,
Am I missing Something? Is there an alternate way to achieve this?
Ilaya.
Message 1 of 1
(1,893 Views)
