Digital I/O
No DAQ Assist Icon on Labview
First of all, I am pretty new, I have never used NI's system.
I am trying to capture the Digital signals via USB-6366 on Labview. However I can not see the DAQ assist icon on Labview.
I believe this USB-6366 is recognized on MAX, and see digital signals via Test Panels.
How to come up the icon on Labview?
My ultimate goal is to capture digital signals and put into DSP(like Low Pass Filter and so on).
(2,169 Views)
Accepted by topic author KevWhat
1. You can post images directly instead of making an Excel file.
2. What version of DAQmx did you install?  I do see that you are using LabVIEW 2014 and MAX is a 2014 version.  So it is likely the version of DAQmx is fine, but we do still need to check it.
3. Did you install LabVIEW before or after DAQmx?  If after, that is your problem.  The drivers do not install support for a version of LabVIEW that is not installed.  So you need to make sure you install DAQmx after you install LabVIEW.  You can simply re-run your drivers installer and it should be just the LabVIEW support that gets installed, making it a quick process.
GCentral
(2,142 Views)
Your diagnosis is correct. Labview 2013 had installed and recognized USB-6366.
I am clear. Thank you for your support.
Best,
(2,124 Views)
