Digital I/O
NI DIO 6534 pattern output
How to use DIO 6534 to generate signal to SPI bus ?
The instrustion code is 00000011b (03h), write status code is 00000001b (01h), SPI address is 2 and then with data 66d.
How to written in LabView code using the digital I/O ?
thanks
(3,253 Views)
Hello YCHENG,
While SPI signals are something the 6534 is certainly physically capable of generating/acquiring, we do not have any LabVIEW example code that implements the protocol.
The place you would have to start at would be generic pattern input/output. From there you would have to develop VI's that format/interpret the packets etc...
Russell
Applications Engineer
http://www.ni.com/support
(3,253 Views)
