From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Digital I/O
NI 9401 TTL to non-TTL signal
Hi Everybody,
I am using Labview FPGA modules. I want to trigger 5V relay.  I have got a NI-9401. This is 8 channel 5V TTL digital out module. But my relays isn't triggering with TTL signal.
Briefly, How Can I Use my TTL Signal to Generate a non-TTL Digital Signal?
Have a nice day!
(2,616 Views)
What relay are you using.  Generally, relays need a good amount of current in order to switch.  DIO generally cannot source that much current (2mA for the 9401 from what I can gather from the datasheet).  So you may need to add a buffer circuit to get the current draw you need.
GCentral
(2,589 Views)
I am using relay in attachment. I think this problem is about inadequate current. You are right. Well, may I do buffer circuit with Labview? Or is the buffer circuit only hardware? Can you help me ?
(2,577 Views)
That is quite a bit of coil current.  You may need a buffer chip and something like a Solid State Relay to control that relay properly.  Something like a SN74ACT245PWR  buffer chip with a DO061A SSR should do the job.
GCentral
(2,561 Views)
Thank you for your advice
(2,558 Views)
