Thank you very much for answering!
Actually, I have taken the "Digital - Continuous Output.vi" example, as I would like to generate the same code continuously, so I think that this example would fit me better. Am I right?
First, I am trying to make the example run in my HW, and then, to modify it to adapt it to my needs.
But, I think that there is something that I don´t understand in the example, since I can´t configure it correctly so that I can see that the outputs change their values.
The configuration that I am using is the following for PXIe-6612, which in my case is in Slot 2:
- Line(s): PXI1Slot2/port0/line8:14
- Sample Clock Source: /PXI1Slot2/PFI0
- Sample Rate: 1000
- Number of Samples: 1000
Please, could you tell me what I am not configuring well?
