Digital I/O
IMAQ .BMP compression
I am encountering an issue with ' IMAQ write file 2' vi.
I want to save a file as a *.BMP without compression.
The file is returned compressed with the RLE_8 algorithm.
I am giving "False" as compression parameter.
This issue was not happening before migration on win10 computer.
(2,076 Views)
Could you attach your code?
Why do you need to have the file compressed?
Michael
(2,041 Views)
this is the code to save the bmp.
I said I don't want the images to be compressed.
With a 2016 32 bits labview the images are saved compressed.
With a 2016 64 bits labview the images are not compressed.
(2,037 Views)
There's nothing wrong with your code so it may actually be a problem elsewhere.
Can you use a newer version of LabVIEW? It may be a bug that has been fixed in a newer version.
Michael
(2,032 Views)
