Digital I/O
Driver
I need some help, where I can find the driver for NI 9403 series C?
(2,355 Views)
What chassis are you putting that module in?  If a cDAQ, then you use DAQmx.  If using a cRIO, then you need to use LabVIEW RT and/or LabVIEW FPGA with the cRIO drivers.
GCentral
(2,349 Views)
It's a chasis cDAQ 9178 Im using DAQmx, but accidentaly I removed the driver, now I can't find it, ?do I need to reinstall DAQmx?
(2,338 Views)
That would be my first step.
GCentral
(2,315 Views)
Accepted by topic author jmarti79
Hello jmarti79,
If you uninstalled DAQmx you will need to reinstall it in order to see your chassis and module under NI MAX.
You can download DAQmx through ni.com/downloads. Select the appropiate DAQmx version according to your LabVIEW or IDE version.
Let us know if this helps!
Fernando Becerra | Field Applications Engineer | National Instruments | CLA | CTD
(2,297 Views)
