Digital I/O
Can I generate PWM output using NI 9472?
Hi, I'm using NI cDAQ-9185 chassis and NI 9472 (digital output) module. From NI 9472 datasheet and getting started guide, there was no explanation of whether the pins have a PWM output or not. I have searched for while not but can't find it. Can anyone help? If NI 9472 module doesn't have a PWM output, can you please suggest which module can give that PWM output?
Thank you in advance.
(1,235 Views)
Typically you'd use one of the chassis' internal counters, "DevChassis/_ctr0", and then configure the task to route the output signal out a particular pin of your digital module, "/DevChassis/Dev9402/PFI0".
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW?
(1,210 Views)
