07-25-2012 08:19 AM
I am using the module NI-9472 (digital output) to switch a din-rail Relay with 24V DC that is switching a 3phase contactor, but am I getting the error 50808 when using this module with the cDAQ-9172 on slot 1.
I have tryed the same application, with the same 9472 module with cDAQ-9171 and everything is working ok. The problem only pressists with the cDAQ-9172 and only when I connect the cables from the 9472 module to the relays. If these cables are disconected, I never get the error, and the module LEDs work just fine.
I am also posting the VI I am using in order to get some help, maybe I should do this in other way.
Thank you for the help.
07-26-2012 12:08 PM
DAQmx returns these errors after the host PC's USB controller reports a USB transaction error.
To recover from this state, you may use this : Programmatically Reset USB DAQ device in LabVIEW
The underlying issue could come from the host controller, the device, or even the USB cable. Some host controllers are more susceptible than others to encountering these transaction errors. It is recommended to double-check your USB cable and if necessary try the device on a different host controller.
You could try a different USB host controller (PCI USB host controllers cost typically between 20 and 30 dollars).
You'll find all these information in the following document : Why Do I Receive Error -50405 or Error -50808 Using an NI USB DAQ Device When Inserting or Removing ...
FYI, a customer who met the same issue get the 9172 working by using an externally powered USB hub.
Regards
Jérémy C.
NI France
07-08-2013 04:15 AM
I have also this problem. The system is already 4 years running without this problem.
I look at the FQA, but the link is broken.
Where is the document now ??
Kind rgeards,
B. Cornet
07-08-2013 08:15 AM
Hello BasC,
The document is now internal but it contains basically everything I wrote.
The only part I didn't wrote is the following one :
DAQmx returns these errors after the host PC's USB controller reports a USB transaction error. According to Intel's specification, a transaction error is any error that caused the host controller to think that the transfer did not complete successfully.
Jérémy C.
NI France
