04-06-2022 12:49 PM
I upgraded DQMH to the latest version via VIPM and revalidated some modules and it has unleashed hell on my project. I then tried to create a DQMH project from the DQMH template and even the initial modules that are created have a broken run arrow. If I follow the errors down it leads me to the following place (see screen shot). How can I fix this so that I have a working DQMH module?
04-06-2022 01:06 PM
It looks to me like the source files in vi.lib didn't get updated properly, this is likely related to the VIPM Community vs. NI Tools Network repository issues described in another thread when DQMH 6.1 first released.
I suggest uninstalling DQMH 6.1 via VIPM (all 5 packages), verifying the source files in vi.lib were removed properly, then re-installing DQMH 6.1, making sure that you're pointing to the correct LabVIEW install when you do so.
04-11-2022 10:49 AM
I attempted this before seeing your reply and it did indeed resolve my problem.
