ni.com is currently experiencing slowness.
Support teams are actively working on the resolution.
DQMH 7 Clonable Scripting Issue
I have a module template for cloneable modules. As part of the template I have an child class implemented for both the Module Admin and the Message Queue. When I try to add a request and wait for reply (or round trip) I get the following issue:
Where the scripting has correctly identified/linked the property node to the tunnel.
Is this a known issue or is there something further I have done which could have caused this?
It's also probably worth noting this only occurs in my MHL the EHL and Helper loops work fine.
(353 Views)
This bug has been filed to the DQMH Consortium as Issue #918. It appears to only affect Main VIs that use a custom child class of the cloneable module admin class. For now, the only workaround is to manually fix the broken wire in the MHL after the scripting is done.
(319 Views)
