01-15-2021 05:32 PM - edited 01-15-2021 05:37 PM
Hey everyone,
I have a rather strange issue (at least to me)...
I build a DQMH module that does some manipulation of NSVs, which are hosted on a myRIO, which in itself is kind of a HIL system.
Everything runs fine in LabVIEW dev environment. Building LVLIBP runs smoothly as well (mass-compile and "saving all" executes flawlessly)..
But... When I choose the API Tester VI from the created LVLIBP in TestStand (2020), I get the following error:
And it only happens with this VI.. All other VI show up working in TestStand..
None of the suggestions help with ithe issue..
I also tried most basic stuff like disconnecting type defs, etc.
*EDIT: The API Tester VI is part of the LIB just for building the LVLIBP and is moved back out as per Fabiola's recommendations..
Run out of ideas.. any pointers here??
Thanks!
Cheers
Niels Göran
01-15-2021 05:47 PM
Apparently, I didn't properly tried the "Disconnect type defintions"..
Set check mark for real, issue fixed ..
Whatever happened there..
01-21-2021 09:19 PM
Glad you were able to fix it, yes, building PPLs is an art... or magic... and thanks for coming back to let us know what worked for you.
Fab
01-22-2021 12:40 AM
Hey hey,
by the way, any thoughts on strucutres in LVLIBPs (probably also magic required):
Thanks!
Niels
