DIAdem
How to consistently connect to the external debugger( Visual Studio Code ) to debug diadem python scripts in Diadem 2023 Q2
So I have been trying to use some the inbuilt of the examples to practice external debugging using Visual Studio Code. However I have been unable to get it to work consistently so far it only work once but most the time it's just fails with Visual Studio Code say it can't connect
and Diadem giving the following error see bellow:
In Visual Studio Code my json file  is as what is bellow:
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
            "name": "Python: Remote Attach",
            "type": "python",
            "request": "attach",
            "connect": {
                "host": "localhost",
                "port": 5678
            "pathMappings": [
                    "localRoot": "${workspaceFolder}",
                    "remoteRoot": "${workspaceFolder}",
            "justMyCode": true
Python code :
import sys
if 'DIAdem' in sys.modules:
    from DIAdem import Application as dd
    if dd.AppEnableScriptDebugger:
        import debugpy
        debugpy.configure(python = sys.prefix + '\\python.exe')
        if not debugpy.is_client_connected():
            try:
                debugpy.listen(5678)
            except:
                pass
                debugpy.wait_for_client()
sPathDocuments = dd.ProgramDrv + "Examples\\Documents\\"
sPathData      = dd.ProgramDrv + "Examples\\Data\\"
dd.Data.Root.Clear()
dd.DataFileLoad(sPathData  + "Example_data.tdm", "TDM", "Load|ChnXYRelation")
oResultChnList = dd.Data.CreateElementList()
oResultGroup = dd.Data.Root.ChannelGroups.Add("Quantize")
oResultGroup.Activate()
oSourceChn = dd.Data.GetChannel("[1]/[3]")
dMax = oSourceChn.Maximum
dMin = oSourceChn.Minimum
dResolution            = 100
sChnResultName         = oSourceChn.Name + "_Quantize_" + dd.str(dResolution, "d.")
oResultChnTempList     = dd.ChnQuantize(oSourceChn, sChnResultName, dResolution, dMin, dMax)
oResultChnList.Add(oResultChnTempList(1))
dResolution            = 2**8
dResolution            = 2**15 - 1
dResolution            = 2**16 - 1
dResolution            = 2**31 - 1
dd.CHNSUB(oSourceChn, oResultChnList(1), "Err_" + oResultChnList(1).Name)
dd.CHNSUB(oSourceChn, oResultChnList(2), "Err_" + oResultChnList(2).Name)
dd.CHNSUB(oSourceChn, oResultChnList(3), "Err_" + oResultChnList(3).Name)
dd.CHNSUB(oSourceChn, oResultChnList(4), "Err_" + oResultChnList(4).Name)
dd.CHNSUB(oSourceChn, oResultChnList(5), "Err_" + oResultChnList(5).Name)
oQChnName      = oResultGroup.Channels.Add("Quantize_ChnName", dd.DataTypeChnString)
oQChnTyp       = oResultGroup.Channels.Add("Quantize_ChnTyp", dd.DataTypeChnString)
oQChnMaxErrVal = oResultGroup.Channels.Add("Quantize_MaxErrVal", dd.DataTypeChnFloat64)
debugpy.breakpoint()
for iLoop in range(1, 6):
    oQChnName[iLoop]      = oResultGroup.Channels(iLoop + 5).Name
    oQChnMaxErrVal[iLoop] = oResultGroup.Channels(iLoop + 5).Maximum
oQChnTyp[1] = "Byte"
oQChnTyp[2] = "Byte"
oQChnTyp[3] = "Integer"
oQChnTyp[4] = "Integer"
oQChnTyp[5] = "LongInteger"
dd.Report.LoadLayout( sPathDocuments + "Channel_Quantize.TDR")
dd.Report.Refresh()
My Python version is 3.10 and environment was installed with Anaconda
(577 Views)
Accepted by topic author JamieA99
I have been able to get it to work now . i don't really know what's changed but it works so this can be closed now.
(516 Views)
