04-29-2022 02:22 AM
I want to ask whether there is a feature allowing us to filter values in different channels in DIAdem.
For instance;
I have a data set being made up of Temperatue1 and Temperature 2. These's sampling rates are different. I am trying to search the times intervals where Temperature 1 is higher than 100 °C and Temperature 2 is lower than 30 °C. Is it possible with DIAdem?
Note: I do not mention about searching files with Data Finder. I am talking about searching time intervals with value conditions in my data set. However, If the case that I mentioned might be executed with Data Finder, I would want to use Data Finder, too.
Thank you.
Mehmet Subaşı
04-29-2022 03:59 AM
Hi Mehmet Subaşı,
You can use the event search function for this. Define the single condition for each temperature and combine the conditions.
Greetings
Walter
05-02-2022 06:38 AM
More examples of using DIAdem's powerful event search:
http://www.savvydiademsolutions.com/blog.php?topic=blog-filter-channel-data-by-events
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
