Our online shopping is experiencing intermittent service disruptions.
Support teams are actively working on the resolution.
06-12-2014 10:24 AM
It it possible to display smooth curves in VIEW using the line fucntion as opposed to seeing jagged stepped curves? I'm looking for and Excel style look, but the data I go through makes Excel much less desirable. I'm looking to have a smooth curve connection between data that is report at ~15Hz. Thanks for your help in advance!
06-16-2014 06:45 AM
Have you tried any of these curve fitting or smoothing functions yet? They can be found in the Analysis pane. Consult the help document to see the differences between the functions.
I hope this helps.
ConnorM
06-16-2014 09:43 AM
The functions you mentioned are in the analysis tab and require me to "do" an analysis on the data. I am curious to know if there is a way to generate a smoothed curve within the VIEW tab without having to do an analysis and simply changing a setting.
06-16-2014 01:01 PM
Hi dc13,
There is such a setting in REPORT, but not in VIEW. The best you could do would be to create a custom VBScript and house it in a custom button or menu for you to select in VIEW, but the script would have to call the ANALYSIS routine.
Or switch to REPORT,
Brad Turpin
DIAdem Product Support Engineer
06-16-2014 01:14 PM
Hmm, that's what I was figuring it would come down to. Ok, I guess that'll have to work. Thank you.
