06-16-2014 06:21 AM
I try to use the "Map View" and I get stuck when I realized my registration data in the cache.
My computer work and nothing is recorded, I have the information at the bottom left that appears: please wait, the map data is saved to the hidden Being ... "
Of empty folders create this but nothing is recorded in the inside.
THANKS FOR YOUR HELP,
Vincent POTTIER
Essais Véhicules, valves et Systèmes / Vehicles,valves and systems Test
POCLAIN HYDRAULICS
BP 106 - 60411 Verberie Cedex - FRANCE
06-19-2014 07:33 AM
Did you try it without "registration data in the cache"?
Simyfren
06-19-2014 08:55 AM
Hi Simyfren,
Thank you for you help,
I tested without "registration data in a cache",here does not work, the map is displayed but the gps coordinates do not correspond to the map display, i dont no why?
Popote
06-19-2014 08:57 AM
Try to check: Show track, then press OK and then Play (Ctrl+F5).
Simyfren
06-19-2014 09:11 AM
Show track, then press OK and then Play (Ctrl+F5).:
here does not work either nothing moves!
06-19-2014 09:14 AM
And do you see the track?
I had also problems with moving, and the problem was the correct format of time channel.
Simyfren
06-19-2014 09:21 AM
You can see my format of time channel (seconds), with view when i play the curves.
06-19-2014 09:24 AM
The map does not match my test area (Germany while my tests are France)
06-19-2014 09:26 AM
And If you try manually "move to France" and try to find your GPS position, do you see your track?
Simyfren
06-19-2014 09:40 AM
I realized one more chance, that you don't have a correct GPS data format.
Simyfren
