DIAdem Idea Exchange
JuliaDawkins
Loading multiple channels into their group names from NAVIGATOR Search Results
Status: New
When I am loading multiple same-named channels into the Data Portal from a DataFinder Search Results list (after 'searching for channels'), if I load these channels into the data portal, by default they all load into the 'default' group, and because they have the same name, they are re-named inside the Data Portal with suffix numbers.
I think it would be better to create a new group in the Data Portal with the name of the group the channels belong to in their respective files, or at least provide this option.
1 Comment
JuliaDawkins
Well the new (DIAdem 2023 Q2) load group or file new option in the data finder context menu when searching for channels or groups is pretty close to this so thanks!
