Community Documents
Electrical Power Measurements with LabVIEW and CompactDAQ
These VIs demonstrate how to take power measurements using a CompactDAQ chassis.  The Simple Power Measurements.vi uses the NI 9225 module to measure up to 300 Vrms of voltage and the NI 9227 module to measure up to 5 Arms of current.  The modules are in slots 1 and 2 of an NI cDAQ-9174 CompactDAQ chassis.  For this example, you will need to download and install the NI LabVIEW Electrical Power Suite.  The subVIs in this palette will automatically calculate power characteristics like the power being used and the power factor.
An additional VI entitled "Power Measurements and Additional Functionality.vi" is included to show additional functionality that can be achieved in addition to power measurements.  In this example, an NI 9213 module is being used to measure temperature while an NI 9234 module can be used to take sound quality measurements.  The NI 9225 and NI 9227 modules are still being used to take power measurements similar to the other example included.  This example also uses an NI cDAQ-9178 CompactDAQ chassis to allow for the additional expansion of up to 8 modules. In addition, this example will require the NI Sound and Vibration Toolkit because of the sound quality measurements that are being taken.
To see this code running for a complete USB-based power measurement system, feel free to check out the Electrical Power Measurement System.
Regards
Noah R
Applications Engineering
Comments
kidderj
Member
Member
on
The newer Tool Pallet does not support the examples. Please fix.
Tommy_G
Member
Member
on
Hi kidderj,
The examples should now work with the new NI Electrical Power Suite.
Tommy
Tommy G.
Product Manager - Search
hamza11
Member
Member
on
I need activator code for electrical power suit.
Contributors
