10-12-2023 04:29 AM - edited 10-12-2023 04:30 AM
Hello, i want to control vFlash with LabVIEW.
Vector provide a API to control it but it is not implemented to using it with LabVIEW. I have wrote a Library to call the API to Flash my ECU. Hovewer by step LoadFlash LabVIEW complete Freeze and i must shut it down with the Task Manager.
Here is my LabVIEW code and DLL Library Code:
using System;
using Vector.vFlash.Automation;
namespace vFlash
public class ECU : IDisposable
private long projectHandle; // Define a private backing field.
public string ECUname { get; private set; }
public string ProjectPath { get; private set; }
public long ProjectHandle { get; set; }
public uint ChannelID { get; private set; }
public uint PercentProgress { get; private set; }
public uint TimeRemaining { get; private set; }
public VFlashStationStatus Status { get; private set; }
public VFlashStationResult Result { get; private set; }
public ECU(string Name, string projectPath, uint channelID)
ECUname = Name;
ProjectPath = projectPath;
ChannelID = channelID;
TimeRemaining = 0;
PercentProgress = 0;
public VFlashStationResult Initialize()
VFlashStationResult initializeResult = VFlashStationAPI.Initialize();
return initializeResult;
public VFlashStationResult LoadFlash()
long projectHandle = ProjectHandle;
VFlashStationResult loadFlashResult = VFlashStationAPI.LoadProjectForChannel(ProjectPath, ChannelID, out projectHandle);
ProjectHandle = projectHandle;
return loadFlashResult;
public VFlashStationResult StartFlash()
VFlashStationResult startResult = VFlashStationAPI.Start(ProjectHandle, progressCallback, statusCallback);
return startResult;
private void progressCallback(long ProjectHandle, uint progressInPercent, uint remainingTimeInSeconds)
PercentProgress = progressInPercent;
TimeRemaining = remainingTimeInSeconds;
private void statusCallback(long ProjectHandle, VFlashStationStatus flashStatus)
Status = flashStatus;
public VFlashStationResult Deinitialize()
VFlashStationResult deinitializeResult = VFlashStationAPI.Deinitialize();
return deinitializeResult;
public VFlashStationResult UnloadProject()
VFlashStationResult unloadResult = VFlashStationAPI.UnloadProject(ProjectHandle);
return unloadResult;
public void Dispose()
GC.SuppressFinalize(this);
// Finalizer (destructor)
~ECU()
// The finalizer should only be used if the Dispose method is not called.
// In this case, it is responsible for releasing any unmanaged resources.
Dispose();
And my LabVIEW Code:
Can you give me a advice how to solve this?
Thank You
11-13-2023 02:46 AM
I have do some work and write a vFlash VIs, i became no error but still dont work. I have attached all my vFlash VIs.
Can you help me where I have an Error?
