Automotive and Embedded Networks
CCP Get Version Time out error
So, a newby I am... I am running a very simple program attempting to convert an existing MATLAB program into Labview VIs. Should be simple - right 🙂
I have some basic communication working, but trying to get the ECU to resond to a GET VERSION cmd results in a time out
However the CCP spy shows the command went correctly and did not get a response... I am curious why?
The code is simple...
The setup is:
So I am at a loss... I get the same timeout when I try and GetSessionStatus, or SetSessionStatus - which is what I am really trying to do...
Any help would be appreciated..
(6,825 Views)
some questions:
1) which Version of the ECUMC Toolkit are you using?
2) which hardware? NICAN or NIXNET?
3) which OS? which LV Version
4) can you add a NI IO Trace log file of the ECUMC API calls only to this thread which should give us more insight view
5) you may add a CAN trace file if you use the NICAN or NIXNET BusMonitor on the second CAN port and stream all CAN traffic to a log file
(6,818 Views)
