02-05-2013 04:40 PM
I am trying to connect to a device expecting extended CAN addressing through CCP and the ECU toolkit, However I cannot figure out how to set the address to be extended..
I am failing on connect.
02-06-2013 03:51 AM
02-06-2013 03:59 AM
02-07-2013 10:56 AM
Thank you, this was what I was looking for. One note, the example code I installed on my PC from the ECU toolkit, the subCANCompose.vi had the wrong value in it for the 30th bit.
But I got it working.
David
02-07-2013 12:29 PM
as far as I know in fact we allow to set any bit beyond 29 and interpret this as extended IDs as this is not defined in the ASAM standard and other A2L files created by various 3rd party tools dont use bit 30. So we need to be flexible 😉
