From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
Actor Framework Discussions
Hardware Abstraction, Interrupts, and AF
I have a hardware abstraction architecture that is built on AF, and I've recently run into an issue I would like to discuss.
The architecture consists of one Actor for each hardware interface, let’s call it a Transporter. The parent Transporter contains dynamic dispatch methods for Open, Read, Write, Close.  Children of this class contain the device specific functions.  All of this has worked great until….
Consider a full duplex serial port that must transmit and receive at the same time.  In addition data must be received (at the host), timestamped, and passed on for processing in less than one millisecond.  Typical mechanisms I’ve used like polling for elements in a FIFO or checking for an IRQ are not sufficient for this scenario.
My solution:  The Transporter now can launch a nested Actor specifically for reading data.  It has one method.  Wait Forever for IRQ (i.e. it uses the Wait for IRQ with a -1).  It also contains the dynamic dispatch methods to read and process the data when the IRQ asserts.  This solution was also fantastic until… I have three Transporters running on a dual-core cRIO.  LabVIEW initially allocates one clone per processor on the machine.  I have 3 simultaneous calls to Wait Forever for IRQ.  I expected LabVIEW to create the 3rd clone on demand, but I don’t see that happening.  Everything is awesome, until I enable the 3 Transporter.  Any two work perfectly.
Is there a way to force preallocation of the clones?  The execution property is set to preallocate, but does it really preallocate actor methods when you instantiate an actor?
Given the scenario does anyone see a better way?
Wouldn’t it be nice to assign a callback vi to an IRQ Number?  That would solve my problem.
Many thanks, Kevin
Message 1 of 8
(4,902 Views)
Are you sure it is the clone that is the issue?   I've never heard of a failure to create a new clone.  Could something in the clone require a separate core.
Message 2 of 8
(3,987 Views)
From the "Wait on IRQ" documentation, it mentions that each call consumes a thread.
Message 3 of 8
(3,987 Views)
Ah Dang, you're right.  I spaced on that one.  Now I need a new solution because the dynamic dispatch methods can't be in different execution systems.
Message 4 of 8
(3,987 Views)
But they can call subVIs in different execution systems.
Message 5 of 8
(3,987 Views)
I'm not sure that's going to help.
You only have a dual core machine. To do two truely parallel operations, aren't you going to need a third core?
Message 6 of 8
(3,987 Views)
