01-16-2015 04:03 PM
I am getting into using UML. I am familiar with the GOOP UML tool, but it doesn't do sequence diagrams, timing diagrams, state diagrams, activity charts, components, packages, etc.
I will also need to do class diagrams just to be able to talk about them to non-programmer coworkers.
I am looking at Lucidchart.
I have tried Enterprise Architect, but the code generation tools are not for LabVIEW so I think I would like something easier graphically.
What do people use?
Casey
Phoenix, LLC
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
01-16-2015 05:15 PM
I use StarUML which until recently was free (and unmaintained). It is/was open source, so I am not sure what is going on now. You can find Star UML on SourceForge and it seems now that there is a site that has been revived for it (staruml.io). You can "evaluate" indefinitely, but I have no idea why this is being charged for now after all these years.
In either case, I do a lot of diagramming for clients. I have tried to use the GOOP tool but it just seems faster and prettier to do this in StarUML. I looked at Lucid Charts, but couldn't find anything they had over StarUML (and the price of the latter was better at the time...). Hope this helps.
Cheers, Matt
01-16-2015 05:19 PM
OK, my question about StarUML was answered in the FAQ;
Yes. you can use StarUML V1 for any purpose. However, don't forget that the StarUML V1 is no more maintained and cannot be supported.
This has not been maintained for years and has been a great tool. I see no reason to pay for version 2 as this wouldn't integrate with LV in either case...
Let me know if you want to see diagrams that I have produced...maybe this would give you something to think about.
01-17-2015 03:30 PM
For sequence diagrams, I use: https://www.websequencediagrams.com/
Still doesn't generate code, but it is really usefull to describe Actor Oriented Designs where there are multiple messages being sent between actors.
I use the GDS toolkit for UML diagrams for classes, reverse engineering and code generation.
Interested in learning what others are using.
01-19-2015 10:28 AM
I'm confused. I've made sequence and state diagrams in the GOOP UML Tool, and I recall using a package object in class diagrams. Are you arguing that these options aren't very good in GOOP UML?
01-20-2015 02:07 AM
I use Enterprise Architect from http://www.sparxsystems.com.
A really great UML tool but unfortunately it lacks support for forward/reverse-engineering LabVIEW code.
We've planned to write an AddIn for this ourselves, but haven't got the time to do so yet...
I've also tried the GOOP UML tool but it is lacks too many features to be useful.
01-20-2015 06:10 PM
I use http://sequencediagram.org for sequence diagrams, it has no ads and is much quicker than the websequencediagram
01-22-2015 07:01 PM
I will check it out. I like how in the paying version of the websequencediagrams the formats of the reports can be changed, they can be shared with others and has no adds. I found it useful enough that I went for the paying version. It is good to know of other tools that accomplish the job and are free, even if they don't have the bells and whistles.
01-22-2015 07:03 PM
Agreed I even checked with Mikael. There are pacakge diagrams, sequence diagrams and state diagrams. Also the UML diagram toolkit in GDS supports Actor Framework.
01-23-2015 10:49 AM
Just to clarify. I want to create multiple levels of UML diagrams. High level down to low level. I had added the GDS to my LabVIEW 2014 environment and project load times went way up. I have been reading the O'Reilly book on UML and I would like a tool to create all of the various diagrams. My primary interest is for the tool to be easy to use and responsive. I don't want to add an additional drag to the LabVIEW IDE as my projects do a good enough job of that already.
Also, as a follow up we are trying out Lucidchart. So far it fits the bill.
At the end of the day I would love it if I could see what my project does (reverse engineering) or describe what I want new LabVIEW code to do at various levels of granularity. When people talk about a "Zoom Tool" for LabVIEW this is where I would want it. I don't need a tool to see my VIs. They are small enough. I need a tool to see my project.
Casey
Phoenix, LLC
