04-18-2012 07:48 AM
Hello guys
I'm testing LabVIEW 2010 interface of arduino with nano ver3.0
Program I made is of simple making led on/off. But even for simple task like led on/off the program taking about 5 sec (too much). I'm attaching this vi (Digital Write). Same applicable for analog read.
Is it same for Uno or Mega ?
Or I'm doing something wrong ?
Please help !!
Thanks and Regards
04-24-2012 12:46 PM
Hi!
I have an Arduino Nano v3.0, I tried your code, but I had some errors.
I changue few things in your program and I solved it.
Try with this program, changue the name of the serial port that your arduino is using, in my case it was the COM6.
I hope this solve your problem!
Cheers!
04-24-2012 06:34 PM
Hi. Thanks for replying.
Its working on your nano. Its good.
As on now my Arduino nano got some problem. I'm trying to fix it. As soon as it got fixed. I'll try.
08-15-2014 11:15 AM
I think you must be sure about you write here...i tried to do the same that you said but NANO did not work with labview.
08-15-2014 10:09 PM
IIRC, there is a good discussion about the Arduino Nano over in the LINX forums. You might check that out if you want to interface LabVIEW with the Nano.
08-20-2014 07:05 PM
I'm sorry, it works few time ago.
You can check here other cases:
https://decibel.ni.com/content/message/39313#39313
https://decibel.ni.com/content/message/42282#42282
Maybe It can help you.
02-25-2017 01:29 PM
08-06-2017 01:42 AM
Can you please do a program for interfacing Lcd 16*2 using Arduino Nano(ATmega 328)
