To be able to draw 3D images in thin air, myGlobe leverages the persistence of vision quirk of human vision. When the human eye is subjected to multiple images in fast succession it cannot differentiate between them and so they merge into one continuous image. The human eye registers any discrete sequences that happen faster than 20 Hz as a continuous image.
For myGlobe, I'm rotating a curved array of LEDs (along with the myRIO controller and associated circuitry) around an axis-point, with the help of a small motor. The LEDs array flashes with different patterns in quick succession, which fools your eye into seeing a continuous image. For example, I have used myGlobe to display a world map, funky patterns and many emojis. But, of course, you can easily add other designs to your liking.
Additionally, if you are a better artist than me, you could easily create a series of images, which the myRIO can cycle-through to create glowing, 3D animations!
About the Developer.
My name is Viktor Pankov and I'm an Electrical and Electronic Engineering student at the University of Manchester. As part of my industrial placement at National Instruments I was given a week to design and build a cool gadget inspired by the Maker Movement.
How to Make Your Own.
The 3 parts of this design are:
The myRIO must feed a predetermined pattern of binary pixels to the 25 LEDs. The pattern must be synchronized with the ring’s rotation and triggered by the IR LED.
The project is difficult to pull off and requires access to power tools.
Making the LED Ring.
For the LED ring, I cut out a 22-mm wide and 2 mm tick ring out of an old paint bucket with a diameter of 20 cm. To drill holes for the LEDs and afterwards mount the ring onto the whole assembly I cut it in one place. Afterwards I clamped the ring down to a table to straighten it out and then used a 4.5mm drill bit to drill 25 holes with 6mm spacing between each hole. With 4.5mm holes I securely press fit my 5mm LEDs with no glue.
The LEDs.
I used female jumper wires to connect the LEDs to the circuit board. The negative leg of each LED is soldered to the female jump lead. This approach makes maintenance much easier. The positive leg of all the LEDS is connected to a common supply line (See Figure 4), while all the negative legs are connected to the circuit board (See Figure 5). My circuit limits the path to ground to control when LEDs are on.
Measuring Rotation Speed and Precise Image Timing.
For myGlobe to generate a stable image the pattern on the LEDs must always begin at the same instance. The purpose of the IR detector on the ring is to detect each revolution by registering a digital edge each time it moves past the IR LED on the wooden frame. The frequency of rotation is calculated based on the registered digital edges in a given amount of time. Figure 6 shows the IR LED and Figure 7 shows how the IR detector is secured to the ring.
Providing Power.
I’m providing power to the whole rotating assembly using a homemade slip ring. The configuration features a ball bearing, which is insulated from the main rotating shaft by cable insulation. There is cable that runs from the circuit board to the inside ring of the ball bearing. I’ve ensure a continues power supply by firmly pressing a U bracket to the outside ring of the ball bearing. The power circuit is grounded through the housing of the motor. Figure 8 below provides further detail.
Circuitry.
The electronic circuit is design for the following tasks:
Figure 9 shows the pin outs and connections for the circuit.
myRIO Control Program.
The attached LabVIEW VIs run on the Linux Real-time processor of the myRIO. The program registers rotations, calculates the frequency of revolution and feeds the various light patterns to the LEDs
You will also find a zip containing all the bitmaps used in create the images. The files should be stored in /home/lvuser location on the myRIO. (Figure 10)
Requirements.
SW:
HW:
Useful Resources.
Hacker’s Handbook: Compendium of Maker Projects
Preparing Future Innovators With the NI LabVIEW RIO Architecture
