Sensor Type: Temperature Sensor
Manufacture/Model Number: Texas Instruments: TMP102
Link to Sensor: https://www.sparkfun.com/products/9418
LabVIEW or C: LabVIEW
Version of LV: 2013
Description/Instructions on how to use this example:
This example reads data from TMP102 digital temperature sensor, processes the data and displays the data on the waveform chart.
1. Connect the sensor to myRIO.
TMP102 myRIO
V+ +3.3V
Gnd Gnd
SCL A Connector/SCL
SDA A Connector/SDA
2. Check the myRIO target IP Address in the project and make sure the target IP Address is correct.
3. Run this VI.
Code: Attached Temperature Sensor.zip
