Student Projects
Diode Curve Tracer for NI myDAQ
Introduction: Use NI myDAQ to plot the current-voltage (I-V) characteristic of a diode.
The input controls circled in red set the start, stop, and step values for the diode voltage. The measured value of a current shunt resistor is also required. Run the VI to measure and plot the diode current as a function of voltage.
Equipment Setup: An operational amplifier (op amp) and a resistor are required in addition to the NI myDAQ:
Theory of Operation: The op amp circuit uses negative feedback to drive whatever current is required by the diode to make its voltage VD match the desired voltage created by the myDAQ analog output. In this way the measurement points are equally spaced along the horizontal voltage axis. The diode current ID is the same as the current through the shunt resistor RD; the measured shunt voltage on the analog input divided by the measured shunt resistance yields the diode current.
Comments
em_engineering
on
the schematic is interesting to study but can u pls provide some document explaining all the details of the design... pls at least to help a beginner
phong87
on
missing daqmx clean task.vi, why? i have already installed daqmx 9.9.
MiguelGP
on
It doesn't work, in the new versions of MyDaq shows a error dev1 doens't exist.
I'm new user and I don't know how meke the changes that it requires to wotk properly.
Could any one help me with it.
Alex8850
on
Thanks a lot! Excellent code, everything worked perfectly.
Contributors
