measurement studio + MFC
Reply
Highlighted
Newbie: NI DAQ Data transfer to signal processing (FFT)
I have a question about NI DAQ that I open by using Measurement Studio
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Try
            Dim acquiredData() As NationalInstruments.AnalogWaveform(Of Double) = DaqTaskComponent1.Read
            WaveformGraph1.PlotWaveforms(acquiredData)
        Catch ex As NationalInstruments.DAQmx.DaqException
            MessageBox.Show(ex.Message, "DAQ Error", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        End Try
    End Sub
    ' Operation Running End here?'
    Private Sub DaqTaskComponent1_Error(sender As Object, e As DAQmx.ComponentModel.ErrorEventArgs) Handles DaqTaskComponent1.Error
        'TODO: Handle DAQ errors.
        Dim message As String = e.Exception.Message
        MessageBox.Show(message, "DAQ Error", MessageBoxButtons.OK, MessageBoxIcon.Warning)
        DaqTaskComponent1.StopTask()
    End Sub
    Private Sub WaveformGraph1_PlotDataChanged(sender As Object, e As XYPlotDataChangedEventArgs) Handles WaveformGraph1.PlotDataChanged
    End Sub
<<<< As the code that Measurement Studio created by itself ,I am wondering that How can I summerize the Data (Sinnal Processing by using FFT) >>>>>
Also the code in NI .NET c# >> ComplexDouble[]FFTValue = NationalInstruments.Analysis.Dsp.Transforms.RealFft(dataArray); but I do it in VB ,so
Can you tell me to transfer the data to the library of FFT (seperated waveform)as the code show above ,I have no idea how to do it Thanks.
Message 1 of 1
(925 Views)
Reply
