daq.io Support forum
Reply
Highlighted
Latest version of the daq.io Toolkit for LabVIEW: 2.0.2.15
Please download the plugin from here for now: https://www.daq.io/daq_io_lib_daq_io_labview_api-2.0.2.15.vip
V 2.0.2.15 (Mar 09, 2017)
- allows file upload with Token
- set buffer path
V 2.0.2.12 (Feb 24, 2017)
- supports "replace file" function for webcams, etc.
- reformat NaNs in waveforms to support waveform charting on daq.io
- added InPlace Structure to HTTP commands for memory conservation
- global setting to toggle buffer use
- improved buffer reliability and recovery in error states
V 2.0.1.5
- improved reliability of offline mode, buffering
- added Token support for typical datalogging operations
(To generate a Token, log in online at https://dashboard.daq.io and generate a new Token on your user page.)
V 2.0.0.5
- many, many incremental improvements and simplifications in the server API for higher performance and more functionality
- a lot of new features on the web front end (alarms, waveform display, improved dashboard editor, live device view)
- tremendous reduction of communication overhead for typical operations
Peter
CLD | Alliance Partner | Web data storage and visualization | daq.io
(2,394 Views)
Re: Latest version of the daq.io Toolkit for LabVIEW: 2.0.2.15
Hi Peter,
Are you guys considering to launch a NXG version of the MQTT Client?
Mauricio Vidal
VIDAL & ASTUDILLO Ltda.
http://www.vidalastudillo.com
(1,822 Views)
Hi Mauricio,
Currently we do not have the resources to work an an NXG client. But since it is open-source we would be excited if others could take on a lead role here.
Peter
(1,399 Views)
Reply
