04-20-2015 11:53 AM
My final year project is about programming the WSN nodes to communicate with eachother independently without the gateway. Can this be done using a Labview application ? Do you have some helpful examples ? I'm having difficulties with finding the required functions in Labview directories.
Thank You.
04-21-2015 01:52 PM
04-22-2015 05:23 AM
hello,
thank you for your answer
the nodes I m working with are configured to communicate through the gateway. What I m supposed to do here, is to change the topology in purpose to send data from the first node directly to the second node which will send the received data to the gateway.
based on the fact that the nodes and the gateway are programmable, I m looking for the communication algorithm and the firmware of this network so I can change it to be adapted with my objectif, but I couldn't get to it.
is it the right step to take?
04-23-2015 09:55 AM
04-27-2015 09:42 AM
alright, thank you!
