Hi Ahmed,
The availability of a microsecond resolution for timing depends on the onboard clocks or setup that the system allows. These nodes are often used to control/acquire in a non-continuous way to save battery. Therefore, they are required to wake/sleep in cycles that take a couple of minutes generally. What are you exactly trying to do with the node?
