Wireless Sensor Networks
Looking for Advice on Integrating Data Acquisition with LabVIEW
Hello Everyone,
I would really appreciate your thoughts and guidance as I am presently working on a project that uses LabVIEW for data collecting and analysis.
To give you some perspective, my goal is to design a system that can monitor and log environmental factors such as temperature, humidity, and pressure utilising NI hardware. I want to use the NI USB-6000 series devices specifically for this. But since I'm not familiar with LabVIEW or data collecting systems, I need some advice on a few crucial areas:
Starting Out: Which tutorials or resources are the best for getting me up to speed with LabVIEW and the NI hardware? Any beginner-friendly materials would be extremely helpful.
Programming Tip: When using LabVIEW for data collecting, are there any typical pitfalls or recommended practices I should be aware of? I want to make sure that my code is maintainable and effective.
Data management: How should the gathered data be stored and presented? Although I'm thinking of using a database for logging, I'd love to know your opinions on efficient LabVIEW data management strategies.
Community Examples: I would appreciate it if you could also contribute any sample projects or code snippets that show off comparable applications.
Thanks in advance.
Romie
(1,100 Views)
I knew whats answer is too late but...The NI USB-6000 is a solid choice for basic environmental logging. I’d start simple: use DAQmx in LabVIEW to read analog inputs, then build a basic VI that logs to a file (like TDMS or CSV). Focus first on getting clean, stable readings from one sensor before scaling up. Also pay attention to sampling rate and grounding to avoid noise. Once that’s stable, adding analysis is way easier.
(329 Views)
The NI USB-6000 is definitely solid for basic environmental logging. Starting simple with NI-DAQmx in LabVIEW makes a lot of sense — especially just reading one analog input and logging it to something like TDMS or CSV first.
Getting clean, stable data from a single sensor before scaling up is such a smart move. And for example, a https://bitkingz.casinologin.mobi/ yeah, sampling rate and grounding can make or break your signal quality. Once the acquisition side is stable, adding processing or analysis is way less stressful. Sounds like a really practical approach
(316 Views)
