04-18-2012 06:04 AM
Good days after some time can obtain the output voltage, but this value is alwayscontinuous. How to control the output voltage through a boolean? In
order to get this tension when I want.
Greetings.
Hugo Santos
04-19-2012 04:41 AM
Hi Hugo,
thank you for using the National Instruments discussion forum.
First of all, which card do you use?
You should know that when you write a value on an output, it does not change until you put another value.
I think you have to send 0 to your device each time your boolen goes to 0 in order to obtained what you want.
Audrey_P
National Instruments France
04-19-2012 05:15 AM
Good Morning.
The card which I'm used is WSN 3202.
04-27-2012 07:52 AM
Hi Hugo,
I'm not sure to understand your problem, can you tell me if my reformulation is good : you are trying to generate a pulse on a digital output of your WSN 3202 in order to pilot a relay?
If I am right, can you tell us more about the characteristics of the pulse (duration, voltage level, etc)?
Thank you in advance,
Audrey_P
04-27-2012 09:05 AM
04-27-2012 10:03 AM
I'm sorry but I do not understand again: in principle, the four DIO can be used simultaneously!
For the response time, if I understand what you mean, it should depend of the sample rate, which you could choose in your program.
Could you post your program in order I see your problem?
Thank you in advance.
Audrey_P
05-02-2012 04:35 AM
Good morning, in attached send my program. Which difficult in time control on output gate.
05-10-2012 05:12 AM - edited 05-10-2012 05:13 AM
Hi Hugo,
if you are using a simple LabVIEW project, you have to fix the sampling time in the properties of the node (see SamplingInterval.png). But this time to refresh the data has to be quite high. So you must take into account this update time when trying to control your output gate.
Audrey_P
05-10-2012 05:27 AM
Hi, thanks for reply. I can try this way and it worked.
07-03-2012 10:44 AM
Good afternoon, is there any way to get output signal when the 3202 WSN WSN loses contact with 9197? Is there any way to put a door as a relay?
Greetings.
