05-30-2013 06:56 AM
I hope the color is not displayed in the indication tab. Here is the image of it.
05-30-2013 07:00 AM
That was an nice vi to look into very simple , gentle and understandable.
Balaji_DP wrote:
clock LV2011
05-30-2013 07:07 AM
Check your clock again... after 12 moving to 1 pm the hour needle not moving corresponding minutes needle
05-30-2013 07:08 AM
Hi NGupta:
You are right.
I followed the performance of the Windows taskbar clock (Open your windows clock and how the minutes update ever 60 seconds). This carried on to the hour performance that you described.
What do you think of the second version?
05-30-2013 07:11 AM
Second version looks good. But there is small bug between 12 to 1. The hour clock does not move between this duration
05-30-2013 07:29 AM
Bug Fixed (As I mentioned earlier without any additional code).
05-31-2013 05:19 AM
Hi All,
Many of you have made very good VIs. Kudos to you all
Kudos:
I have a few suggestions for everyone:
We still have 4 days ahead of us. Keep improvising
Raviteja Chivukula
Staff Applications Engineer
NI India
06-01-2013 03:02 AM
Attached the working clock, may not be the metallic frame used old clock frame...
06-01-2013 03:18 AM
Hi Arib,
The VI is good. But it would be better if you had used a while loop so that the clock runs continuously. Also, from your picture, I see that you use, 'Run Continuously' option. It is recommended that you use the 'Run Once' button instead. Your VI should have the while loop so that the code repeats.
Cheers
Raviteja
06-01-2013 03:29 AM
Plese find attached the .rar file containing code for Analog clock, developed in LV2012.
