09-25-2013 06:55 AM
Question)
A system consists of a tank containing a liquid and an inlet to this tank. The flow through the inlet is controlled by a valve. The liquid level is sensed and used by a controller to control the valve.
Make and state the necessary assumptions allowed by the real behavior of this system, model this system, and perform analysis on this system to attain:
•The overall Transfer Function
•The State Space and Pole Zero representations
•The Nyquist and Bode plots
•The Overshoot, Settling Time and Peak Value.
•If the system parameters are changed, these quantities should also change.
Leave your answers as comments below by clicking on Reply
You will need to be logged-in to do so. Click here to sign-in/sign-up.
Rules & Guidelines
