Washington Community Group
May Presentation by Seneca5
Seneca5 presented at the May 8th SLUG meeting. Seneca5 is a National Instruments Alliance Partner. We provide engineering, programming, and integration, specializing in National Instruments tools and technologies. You can contact us at www.seneca5.com.
At the May 8th group, we spoke about our design process: Specify, Design, Implement, Verify. And we demonstrated our process in action with a simple cRIO demostration. Attached are the slides from the presentation and the cRIO code we demonstrated*.
(*In order to fully access the code, you will need to have LabVIEW 2011 for Real-Time and LabVIEW for FPGA. If you don't have those, some of the code may appear broken, other parts you will see, but will not be able to run.)
Message 1 of 1
(9,961 Views)
