06-15-2021 01:25 PM
I was going to use the NI Batch Installer Builder to simplify installing LabVIEW 2020 and all the components that I require on a new machine. When I attempted 'Add Installer Copy' I get an error, "Select the root directory of a valid National Instruments installer. The directory you should select contains setup.exe.". When I look in the directory I notice that NI has changed the name of setup.exe to Install.exe. Pretty confusing to say the least. I'm running the latest version of NI Batch Installer Builder (19.0), so that's not a solution. I also tried changing the name of Install.exe to setup.exe but I get the same error.
Any ideas on how to solve the problem?
06-15-2021 10:12 PM
Hi Ben,
Sorry for the confusion! NI's installer technology completely changed in 2019 to be based on NI Package Manager, so NI Batch Installer Builder is not compatible with it. The recommended replacement for building custom installers is NI Package Builder, which is also free.
This is an introduction to Package Builder, and here's where it can be downloaded.
- Wes
06-16-2021 03:46 PM
Ben, FWIW, there are a few known issues with NIPB 20.6 listed here. Please be aware of issue 1436537 that can occur when installing a subset of products included in a "suite" installer built by NIPB.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
