Volume License Agreement Community Discussions
Error connecting to server when installing LV
I am attempting to manage a labview volume license server.  I have installed VLM 3.1 and transferred the license and a back up of the old server.  I have crated an installer for the client PCs.  When I attempt an installation on a client PC I get an error message stating that the client can not connect to the license server.
I am able to log on to the server remotely and I can ping the server over the network.  I have tried to build the installer on a network drive and on the server PC.  I get the same error message.  I have also tried to build the installer using the server name and the IP address of the server.
Can anyone get me pointed in the right direction?  I am not sure what to do next.
Guy
NA
(4,211 Views)
Hi Guy,
I had the same problem. I was able to ping the license server and to connect to it with Telnet from the client but if I called the volume license installer built setup.exe, I got the error message that the connection to the license server is not possible.
In the VLM settings no communications port was entered. After entering a communication port (default 4637) and building a new volume license installer, the license server can be accessed from the setup.exe.
Andi
Andi
(4,039 Views)
