Volume License Agreement Community Discussions
DVD software disks with AutoRun.inf causes a problem
We have a virtual machine that we use for our VLM.
The procedure in the past has been to copy the DVD disks to a directory on the virtual machine.  Then create a Volume License Installer on the virtual machine.
My problem is the autorun.inf file does not copy.  I believe it is trying to run instead.  When this happens Windows Explorer stops and does not copy the file.  There is a file (or more than one) on the second disk that is also causing a problem.  I have not determined which file is causing the problem on the second disk.  There must be a better way.
Is there are way to transfer the DVDs to the Virtual Machine?
Message 1 of 1
(3,055 Views)
