2
VBAI
Advanced Edge, Multi-edge mode: When expecting N edges, SNR noise needs to be calculated based on the residual RMS signal level to avoid inappropriately low SNR reporting.
Currently, the edge #1 SNR is based on strength of edge #2 which will result in a very low SNR for edge #1 if #2 has a similar strength.
This feature idea has been accepted and is implemented in VBAI 2014 SP1, which is now available.
