Vision Idea Exchange
About Vision Idea Exchange
Have a Vision Product Idea?
  1. Browse by label or search in the Vision Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. Be sure to submit a separate post for each idea.
    Note: Please post technical vision support questions to the Machine Vision forum, not the Vision Idea Exchange.
  4. As Vision R&D considers the idea, they will change the idea status.
    Note: Vision R&D is committed to reviewing every idea posted in the Vision Idea Exchange. However, the implementation of any Vision Idea Exchange submission cannot be guaranteed.
  5. Give kudos to other ideas that you would like to see implemented!
Find Edge Annulus Improvement
It can be improved in two ways:
1) It should work in radial direction with gap parameter in order to better apply different scenarios. Similar to Find Circular Edge function, but the aim is search for defects rather than a diameter. So, it could be implemented in the Annulus Tool of Find Edge function.
2) Many annulus should be added like a combination of image 1 and 2, with two gap parameters.
Current workaround is using a polygon tool, which is very time consuming and not fully functional.
CircEdge.JPG1)EdgeAnnulus.JPGworkaroundAnnulusRadialGap.JPG2)
