Problem:
I need to acquire images from a camera and rotate them 90-degrees counter-clockwise on a cRIO-9034 target. Rotating the image on the camera sensor is not supported by the camera.
Current situation:
It is currently possible to rotate an image using “IMAQ Rotate.vi”. This VI has a floating point input angle which can be set to 90 degrees. It is however a bit slow (around 80 ms on a cRIO-9034 for a 3840x1200 image). It should be possible to implement a faster way of rotating an image when the angle is in increments of 90 degrees.
My suggestion:
Create a new IMAQ vi for rotating images in increments of 90 degrees. The VI could be similar to "IMAQ Symmetry.vi" which can be used to flip images horizontally and vertically.
