04-18-2018 02:46 PM
Is the sample rate for Power supply output read-back same as its DMM sample rate (5 samples/sec)?
04-19-2018 05:48 AM
I thought it was quicker than that but the resolution is far less.
From using the example vi from the link below it appears to be around 1mS per sample.
04-19-2018 10:14 AM
Did you mean 1"milli-second" per sample?
04-20-2018 03:20 AM
Yes, that was using a flat-sequence method.
Basically Put the vi in a flat sequence and put a 'High Resolution Relative.vi' before and after and subtract them from on another.
Another way to get a more detailed output is to go to [Tools >> Profile >> Performance and Memory]
Then you get a break down of memory use and timing of all sub vis within a vi runing a run period.
04-20-2018 08:59 PM
Thank you for the details Stephen. But, I am using C-API to get measurements. I do not have LabView interface.
Is there any documentation that specifies the sample rate?
I could not find it in VB-8012 spec sheet.
