I'm new to VirtualBench and could not find this question answered elsewhere. I'm trying to set up a SPI bus on the Logic analyzer, but the analyzer only give pin settings for CS, Clock, and "Data". A SPI bus should consist of CLK, CS, MOSI, and MISO. Am I supposed to sret up a separate bus for MOSI and MISO, or am I missing something here?
Hrm, I may have replied a little quickly. Those lines are if you're mastering SPI with the GPIO pins.
If you're using the logic analyzer to decode a spi bus with the VirtualBench application, you can just set up a second "bus" to decode both MOSI and MISO at the same time.
