03-22-2018 12:08 PM
I am able to get the frequency from the VirtualBench however I have no idea how to get the amplitude of the clock wave.
03-23-2018 05:47 PM
Can you provide more information on what you mean by clock wave? Is it a signal that you're generating? Is it a signal that you're reading in?
Here're some links that might be helpful:
Mixed Signal Oscilloscope Pinouts and Connections
http://zone.ni.com/reference/en-XX/help/371526C-01/vbhelp/scopelapinout/
Device Specifications NI VB-8012
http://www.ni.com/pdf/manuals/371527d.pdf
Misbah Dhuca
03-28-2018 07:48 AM
Hi Misbah,
I am using the Mixed Signal Oscilloscope to read a clock signal from a motherboard. There is a computer connected to the VirtualBench that uses a ANSI C program to read information about the signal from the VirtualBench. I looked at the pdf you send me and on pg4 under Waveform Measurement / Oscilloscope Voltage, I'm trying to get the value of the amplitude. Is there a way to do that using ANSI C?
03-29-2018 04:25 PM
Hi Quintin,
Thanks for the clarification.
Are you trying to see the amplitude in VirtualBench or are you trying to use it in your code?
Also, I found this in another forum post:
If you install ANSI C support during the NI-VirtualBench driver install, after the install completes you should find a VirtualBench C Reference Help.chm at C:\Users\Public\Documents\National Instruments\VirtualBench Documentation as well as example programs at C:\Users\Public\Documents\National Instruments\VirtualBench ANSI C Examples.
If you don't see these files currently, you can go to Control Panel >> Programs and Features >> National Instruments Software, find the VirtualBench ADE Support, and do a modify install.
I'd look into these examples to see if there is one that works with amplitude.
Best,
Misbah
