Version Conversion
Please help me convert these files from LabView 8.0 to LabView 2024
Hello, these files were previously used in labview 8.0 and we need to upgrade to windows 11 were labview 8.0 doesn't run well. As such, we have moved to labview 2024 but these files will not work. Could someone please help out and convert them for use in labview 2024?
Best wishes,
Jack
(759 Views)
Accepted by WJDalton
What issues are you having?  LabVIEW 2024 will open VIs from LabVIEW 8.0.  Where you might be having issues is the dll as that will likely need recompiled to work with Windows 11 and possibly compiled in 64-bit if using LabVIEW 64-bit.
(738 Views)
Thank you for for pointing out about the 64 bit! I switched to using a 32 bit version of labview 2024 and its all running perfect now. Also, apologies it took long to respond - we had lots of issues with IT and the PC we were using so I need to set it all up again on a new PC.
(688 Views)
