Version Conversion
Reply
Please help convert from LabVIEW versions 5.1 to LabVIEW 7.1
Highlighted
Vi in attached are from legacy LV Version 5.1.  Appreciate you help in converting the Vi to a form that can be read by LV 7.1.
Thank You!
(79 Views)
Re: Please help convert from LabVIEW versions 5.1 to LabVIEW 7.1
Your VI do not have block diagram.
It is therefore impossible to convert.
Benoit
(74 Views)
Benoit
 Thanks, Is the block diagram empty? Can you help me  try again?
(63 Views)
Benoit
(63 Views)
Accepted by topic author luckbetty
11-07-2018 11:05 PM
This is the error message.
Find another source of the VI. It is common to prevent VI from being hacked to remove the block diagram when distributed.
In that case, only in the original version the VI can be opened.
Benoit
(56 Views)
Benoit
    I see ,thank you very much!
Betty
(54 Views)
My pleasure!
Benoit
(45 Views)
