Version Conversion
Convert LV8.2.1 to LV2020
Highlighted
I need to have the attached VI file converted to work with LabView 2020.
(185 Views)
Highlighted
Just open the VI in LabVIEW 2020.  Are you having an issue opening it?
GCentral
(170 Views)
Highlighted
I can open the file just fine. When I click Run an Error -201003 occurs. It reads "Error -201003 occurred at DAQmx Create Channel (AO-Voltage-Basic).vi:187005"
Possible Reasons
Possible reason(s):
Device cannot be accessed. Possible causes:
Device is no longer present in the system.
Device is not powered.
Device is powered, but was temporarily without power.
Device and/or chassis driver support may have been removed.
Device is damaged.
Ensure the device is properly connected and turned on. Ensure the device and/or chassis is supported in the current version of the driver. Check the device's status in NI MAX. Turn the computer off and on again. If you suspect that the device is damaged, contact National Instruments at ni.com/support.
Device Specified: cDAQ1Mod1
Task Name: _unnamedTask<0>
The device I'm using is no longer supported by the current NI DAQmx. I had to download some old drivers, but I don't know if the old drivers are compatible with LabView 2020. Are they?
(159 Views)
Do I need an older version of LabView since I'm using a CDAQ-9172 that requires NI-DAQmx 8.5?
(154 Views)
Highlighted
Accepted by topic author jjohnstonFieldUSA
Yes.  Read.  https://www.ni.com/en-us/support/documentation/compatibility/17/devices-and-modules-no-longer-suppor...
According to that, you can use up to DAQmx 17.5.
Then read NI-DAQmx and LabVIEW Compatibility
According to that, the newest version of LabVIEW that supports DAQmx 17.5 is LabVIEW 2017.
(148 Views)
Highlighted
Very helpful! Thanks!
(145 Views)
